Release date: October 26th 2021
This page provides more information about the newly released functionality, improvements, and bug fixes in UiPath Process Mining 2021.10.
New features
Sending automation ideas to UiPath Automation Hub
When setting up integration with UiPath Automation Hub, by default, a connection is set up to Automation Hub in UiPath Automation Cloud. It is now possible to connect to an on-premises version of Automation Hub, by specifying the URL to the desired Automation Hub instance in the AutomationHubUrl Server Setting. See [Set up Integration with UiPath Automation Hub(doc:set-up-integration-with-uipath-automation-hub).
Setting the column width
For table items that have wide values, the text displayed in charts can become (partly) invisible if the column
is too small to display the complete text. It is now possible to specify a column width for a table item. When the table item is used as a text column on a chart, the column width is used as the minimum width for the column. See Introduction to table items.
Language support
Additional to English (en) and Japanse (ja), Process Mining is now available in several other locales. Below is an overview of all supported locales for Process Mining.
AppOne is now also available in these languages.
| Locale | Setting (ApplicationSettings.json) |
| German | de |
| English | en |
| Spanish | es |
| Spanish (Mexico) | es-MX |
| French | fr |
| Japanese | ja |
| Korean | ko |
| Portuguese | pt |
| Portuguese (Brazil) | pt-BR |
| Russian | ru |
| Turkish | tr |
| Simplified Chinese (China) | zh-CN |
If you have manually added one of these languages in an earlier version of Process Mining, you will get a scan warning after updating to Process Mining 2021.10. In this case, you are recommended to delete the existing translation file from your workspace.
Improvements
Anonymization
For data anonymization, the hashing options are now using methods that comply with NIST policies.
Improved sorting in Superadmin
In the Superadmin page repositories and environments are now also sorted in alphabetical order, which makes it more consistent with other parts of the Superadmin page.
"Now" always updated when reloading data
The value of Now is now always updated when the data is reloaded.
Default table scope
When creating a new connection string table, the Table scope is now set to Server by default.
Other
Setting up Actionable insights
When setting up Actionable insights, you must now specify the UiPath Orchestrator App ID and App secret, which are generated when defining an external application for Orchestrator API access.
See Set up Actionable Insights.
Activities and Edges sliders
In Process Mining 2021.4, the Detail slider was introduced on the Process graph. It is now possible to replace the Detail slider by separate Activities and Edges sliders by specifying the UseEdgeActivitySliders Server Setting.
