Deploying the UiPath Process Mining Profiler
Introduction
With every software release, UiPath will provide you with a link to download the UiPath Process Mining Profiler files.
The UiPath Process Mining Profiler is an application that must be deployed on an environment before it can be used.
Deploying the Profiler
Follow these steps to deploy the Profiler.
| Step |
Action |
| 1 |
Go to the Superadmin Settings tab. |
| 2 |
Add a new environment PG-Profiler to your installation. Note: you must use exactly this name, otherwise you will not be able to navigate to the Profiler from within the profiled application. |
| 3 |
Go to the Superadmin Releases tab. |
| 4 |
Click on the menu icon at the top left and select Upload a release to this server… to upload Profiler.mvtag . |
| 5 |
Right-click on PG-Profiler/<Profiler version> and select Make active on... -24 PG-Profiler . |
| 6 |
Go to the Superadmin Released data tab. |
| 7 |
Select the PG-Profiler environment and click on Generate Cache now . |
| 8 |
Select Workspace in the Dataset field and select All in the Organization field. |
| 9 |
Click on GENERATE CACHE . |
The UiPath Process Mining Profiler is now ready to be used from within an application.
You should make sure that all users that should be enabled to use the UiPath Process Mining Profiler, have access to the new PG-Profiler environment.
Related Iinformation
See: Application Profiling.
