Skip to main content
Using a Git repository
Introduction
Development in UiPath Process Mining is done collaboratively. To facilitate this, and to keep track of changes, Git is used. A Git server can be used by multiple installations of UiPath Process Mining.
There are two methods in which you can incorporate Git:
  • A local Git repository, managed by UiPath Process Mining.
  • A Git repository you manage yourself. This can either be your own Git server, or even a GitHub repository.
    note
    Whichever Git repository you choose to use, you should make sure to only make changes through UiPath Process Mining. Performing Git operations manually (e.g. through the Git command-line tools) may interfere with the proper operation of UiPath Process Mining.
Local repository
Follow these steps to use a local repository within the UiPath Process Mining installation.
StepAction
1Login on the Superadmin page.
2Go to the Settings tab.
3In the Repositories text field, use the following value: [{ "url": "mvlocal:upstream.git}]
4Press CTRL+S to save the changes and reload the page to apply them.
Username and password
Follow these steps to use a Github account using a username and password.
StepAction
1Go to the Settings tab.
2In the Repositories text field, use the following value: [{"url": "https://github.com/username/repo.git", "user": "username", "pass": "password}]
3Press CTRL+S to save the changes and reload the page to apply them.
Hide password
In case you do not want passwords clearly visible in the settings, you can also use a public and private key pair. You will need access to the filesystem of the server.
Follow these steps to use a public and private key pair.
StepAction
1Obtain public and private keys for the Github repository you want to use.
2Place them in the databases directory in PLATFORMDIR. It is recommended to place them in a subdirectory, for example, respectively for the private and public keys: • <PLATFORMDIR>\databases\keys\keyfile.txt<PLATFORMDIR>\databases\keys\keyfile.pub.txt
3Go to the Settings tab.
4In the Repositories text field, use the following value: [{"url": "git@github.com:username/repo.git", "privkey_file": "keys/keyfile.txt", "pubkey_file": "keys/keyfile.pub.txt}]
5Press CTRL+S to save the changes and reload the page to apply them.
A Git server is connected to UiPath Process Mining. Your developers can start committing and collaborating.
