Skip to main content
Setting up a SQL connector
Introduction
This page contains the instructions on how to create a new SQL connector and connect it to your source systems.
Prerequisites
It is assumed that the development tools described in Setting up a local test environment are installed.
Creating a New SQL Connector
If you want to build a new SQL connector you can download the template connector that contains the basic setup for a SQL connector.
Start Repository
It is advised to store your connector in a version control system, for example, GitHub.
StepAction
1Create a new repository that contains the complete connector directory. This directory must have the same structure as the downloaded (template) connector.
Configure Extraction
First, the extraction settings need to be set, to point to the desired source system and staging database. These configuration steps must be done once for each developer environment, and for the production environment.
Step 1: Choose Extraction Method
Each connector comes with a set of specific extraction methods. One of the extraction methods needs to be configured, to extract source data.
Extraction methodDescription
Load-from-file• Set up a CData job for the Load-from-file extractor. See Extractors: Load from file. • Use a custom query specific to this connector, which is provided in extractors/load-from-file/instructions.md.
Load-from-sourceTo load input data from a source system, use the specific instructions located in extractors/load-from-source/instructions.md. The load-from-source extractor is only available in connectors made for specific source systems, for example a Purchase-to-pay for SAP connector.
Step 2: Limit Source Data
Make sure to set the appropriate filters for your extractor, to load only the data that is necessary for your analysis. For example, limit the data to the last 6 months, or only a specific department that’s of interest.
Specific instructions on filtering input data can be found in instructions.md of the extractor.
Step 3: Configure Extraction Script
If the connector uses CData Sync for data extraction, the extract_cdata.ps1 script must be pointed to the correct job. Follow these steps to configure the extraction script.
StepAction
1In the scripts/ directory, rename config_template.json to config.json. config.json is ignored by Git, such that development and production environments can use different extraction configs.
2In config.json, change the text JOB_NAME_CREATED_IN_CDATA to the CData job that was just created.
If the connector does not use CData Sync for extracting data, then use the specific instructions provided in instructions.md.
Configure Transformation
To perform the transformation on the right staging database, profiles.yml needs to have a reference to your staging database for this connector. These configuration steps need to be done once for each developer environment, and for the production environment. Follow these steps to configure the transformation.
StepAction
1Copy the contents of transformations/profiles.yml of your connector.
2Paste the contents in your personal profiles.yml to add those. The personal profiles.yml should be located outside of the connector directory.
3Change the contents to point to your staging database.
Configure Load
To perform cache generation by using the load.ps1 script, it must be pointed to the Process Mining environment on which the corresponding app release is active. Follow these steps to configure the extraction script.
Step 1 can be omitted if it was already performed during configuration of the extraction.
StepAction
2In config.json, change the text PROCESS_MINING_ENVIRONMENT to the environment on which the release is active.
Next Steps
When the SQL connector is set up properly, it can be run. See Running a SQL connector.
