Skip to main content
Understanding the solution development lifecycle
A solution automates a business process. Although we use the term "solution" across the entire lifecycle, the solution is represented by different artifacts at each stage. It starts as an idea, it is built and structured in UiPath Studio, published as a Solution Package, and is finally deployed to the UiPath Platform where users can run and manage it. Depending on the scenario, you can also assemble a Solution Package directly in Orchestrator by combining existing, already deployed artifacts into a deployable package.
note
Before Studio Web introduced a dedicated solution design experience, assembling a Solution Package in Orchestrator was the primary option for putting a solution together from deployed building blocks.
Looking forward, the recommended approach is to build solutions in Studio Web, because solution design is primarily an authoring activity: it benefits from fast iteration, collaboration, and proximity to the developer workflow (defining structure, dependencies, and configuration in one place). Package management and deployment management will continue to be performed in Orchestrator, because they are operational activities: they require controlled distribution, environment governance, consistent versioning, and administrative oversight to ensure solutions are promoted and consumed safely across tenants and environments.
The diagram below summarizes the solution lifecycle and shows how the main artifacts and responsibilities flow across design, packaging or publishing, and deployment.
Solution development lifecycle
