Skip to main content
Document Viewer
Use the Document Viewer control to render a document and display it inline in your app. For example, you can use the Document Viewer control to display an invoice document or a receipt which may be located in various sources, such as storage buckets, entities, or public links.
When assigning the file to an app variable, make sure the variable is of the type AppsFile.
If you only want to display an image, it is recommended to use the Image control.
important
If you are using Google Chrome, depending on your settings, the browser may download the document instead of opening it. This can cause the document to not display correctly in the app.
If you are experiencing this issue, follow these steps:
  1. Paste the following in your Google Chrome address bar: chrome://settings/content
  2. Scroll down to the end of the page and select Additional content settings. A dropdown selection opens.
  3. Select PDF documents.
  4. Select the Open PDFs in Chrome option.
General
  • Hidden - If true, hides the control at runtime.
  • Disabled - If true, disables the control at runtime.
Events
No events.
Style
  • Control Alignment - By default, inherits the parent alignment. A different alignment other than the parent can be set. To default back to the parent alignment, deselect the overridden options.
    note
    The alignment is dependent on the layout selected for the parent (Vertical vs. Horizontal).
  • Border - The border for the control. Border Thickness, Color, and Radius can be configured.
  • Margin - The margin of the control. By default, a margin of 4 px is set. Top/Bottom and Left/Right margin properties are combined. These properties can be detached using the Link button at the right side of the Margin section.
  • Size - The width and height of the control. By default, the size is set to auto, which means 320 x 410px. To set minimum or maximum values, select the three dot icon (...).
VB properties
VB propertyData typeDescription
SourceAppsFileThe source file currently viewed.
ValueAppsFileValue attached or outputted from the Document Viewer control.
HiddenBooleanIf true, hides the control at runtime.
DisabledBooleanIf true, disables the control at runtime.
