Skip to main content
About AI Trust Layer
The AI Trust Layer card allows you to directly oversee and govern UiPath® generative AI features across all UiPath® products. Its purpose is to act as an administrative panel for generative AI as well as any third-party AI models, providing comprehensive management and strict control capabilities, including an auditing and usage panel.
A key tenet of the AI Trust Layer is ensuring that your data remains confidential and secure, never to be shared or reused outside of the UiPath® environment.
The AI Trust Layer page allows you to perform the following operations:
  • Get a clear picture of AI utilization across your organization via the Usage Summary tab: Details...
  • Get an oversight of all AI model-related operation via the Audit tab. Details...
  • Gain control over the AI Trust Layer policies via the AI governance tab. Details...
  • Manage Autopilot for Everyone usage across your organization via the Autopilot for Everyone tab. Details...
  • Bring your own large language models via the LLM configurations tab. Details...
AI Trust Layer configuration checklist
Use this checklist to verify that all AI Trust Layer configurations, governance settings, and integrations in Automation Suite are correctly set up and functioning as expected.
  1. Access AI Trust Layer:
    • Navigate to Admin > AI Trust Layer in the Automation Suite portal.
  2. Review usage summary:
    • Check AI model usage by status, product, and tenant under the Usage Summary tab.
  3. Audit AI operations:
    • Go to the Audit tab to review AI-related operations, model usage, and statuses.
    • Verify logs include model name, location, product, tenant, and user.
    • Export and validate audit logs if needed.
  4. Manage governance policies:
    • In the AI Governance tab, review or add policies from Automation Ops.
  5. Manage Autopilot for Everyone:
    • Install, update, or uninstall Autopilot for Everyone from the dedicated tab.
  6. Configure LLMs for products that use generative AI:
    • Under LLM Configurations, connect your AI provider.
    • Test and validate connections using Integration Service.
  7. Validate audit and compliance:
    • Ensure audit logs retain data.
