Skip to main content
Flex: Licensing plan framework
important
The licensing information on this page applies to you if you are on Flex. If you are on Unified Pricing, refer to Unified Pricing: Licensing plan framework.
You can use Test Cloud for Automation Suite with a licensing plan to match your automation needs and budget.
Plan overview
The following sections provide a high-level description of the licensing plans available in the Flex model.
Enterprise
The Enterprise plan is a yearly plan which includes custom license types and license counts, tailored to your specific needs with help from our Sales team. To get started, you must contact Sales.
You can purchase as many licenses of each type as you want, and you gain access to the full stack of premium plan perks that are included with this plan.
You can also purchase products in bundles, called Platform SKUs. These are currently available under the form of two tiers, namely Standard and Advanced. The capabilites included in each tier differ, and are detailed on the UiPath Licensing page.
Plan breakdown
The following table describes the available benefits:
Plan perks Enterprise
Max. tenants 1 As needed
Max. user accounts As needed
Access to UiPath Support Standard Support; can be upgraded to Premium Support.
USER LICENSES
Attended - Named User As purchased
Citizen Developer - Named User As purchased
Automation Developer - Named User As purchased
Action Center - Named User As purchased
Tester - Named User
As purchased
Includes unlimited Autopilot actions for Autopilot for testers
Insights Designer - Named User As purchased
Process Mining Developer User As purchased
Process Mining Business User As purchased
ROBOT LICENSES (RUNTIMES)
Unattended Robot As purchased
NonProduction Robot As purchased
Testing Robot As purchased
SERVICE LICENSES
Robot Units for VM cloud robots As purchased (annual availability)
AI Units 2 As purchased (only available in the Advanced tier).
Test Manager As purchased
Automation Hub As purchased
Insights As purchased
Apps Included
Action Center Included
Data Fabric
1 unit included for each purchased user or robot license
Can be supplemented with additional licenses purchased
Each unit grants 1 GB of data storage, 5 GB of attachment storage and 10,000 API calls/day.
Document Understanding 3 Included with purchased AI Units
Computer Vision 240 megapixels/min
Integration Service
As purchased - included with purchased user and robot licenses
Supplemented with additional licenses purchased
Process Mining Included with purchased AI units
Communications Mining Included with purchased AI units
1 Each tenant comes with one Orchestrator service.
2 AI units are used to license several of our AI products.
3 Document Understanding public endpoints
