Switching between Active Directory adapters
UiPath® Identity Server provides support for two Active Directory adapters: ad and ldapad.
adadapter: Legacy adapter that works only in standalone deployments. Theadadapter only operates on Windows and it supports external trust domains and NTLM, offering support for non-domain joined clients to authenticate.ldapadadapter: Adapter introduced in 2021.10. Theldapadadapter works in both standalone and Automation Suite deployments and it does not support external trust domains and NTLM for non-domain joined clients to authenticate.
The following table describes the two Active Directory adapters for each deployment model:
| Deployment | ad adapter | ldapad adapter |
| Automation Suite | Not supported | Supported |
All deployments prior to 2021.10 with Active Directory integration enabled keep the ad adapter after upgrade. All other deployments get, by default, the ldapad adapter when Active Directory integration is enabled.
Checking the Active Directory adapter type
To determine the adapter type, a SQL query can be executed which checks the type of the adapter in the [identity].[DirectoryConnections] table.
SELECT dc.* from [identity].[DirectoryConnections] dc
JOIN [identity].[Partitions] p ON p.[Id]=dc.[PartitionId]
WHERE p.[GlobalId]='FEB0DD79-85B6-483B-B297-0E49A1AA5B7D' AND dc.[IsDeleted]=0
If [Type]=ad, then the ad adapter is in use. If [Type]='ldapad', then the ldapad adapter is in use.
Switching from ldapad to ad
This is supported only in standalone deployments.
To switch from ldapad to ad, take the following steps:
- Check that
ldapadadapter is enabled by making sure the following query returns one row:SELECT dc.* from [identity].[DirectoryConnections] dc JOIN [identity].[Partitions] p ON p.[Id]=dc.[PartitionId] WHERE p.[GlobalId]='FEB0DD79-85B6-483B-B297-0E49A1AA5B7D' AND dc.[Type]='ldapad' AND dc.[IsDeleted]=0 - Connect to the Orchestrator/Identity database and run the following script, making sure to replace
FQDN-OF-DOMAINwith the fully qualified name of the default/main domain. With Active Directory integration enabled in the UiPath host portal, the following SQL script updates theDirectoryIdof Active Directory users and groups, soft-deletesldapaddirectory connections, and createsaddirectory connections.-- convert users
IF OBJECT_ID('tempdb..#tmp_ldap_users') IS NOT NULL
DROP TABLE #tmp_ldap_users
SELECT [Id], [MasterPartitionId], CONCAT('ad', SUBSTRING([DirectoryId], 7, 256)) AS [DirectoryId] INTO #tmp_ldap_users
FROM [identity].[AspNetUsers]
WHERE [DirectoryId] LIKE 'ldapad|%' AND [IsDeleted]=0
--SELECT * FROM #tmp_ldap_users
DELETE tmp
FROM #tmp_ldap_users tmp
JOIN [identity].[AspNetUsers] u ON u.[MasterPartitionId]=tmp.[MasterPartitionId] AND u.[DirectoryId]=tmp.[DirectoryId]
UPDATE u
SET u.[DirectoryId]=tmp.[DirectoryId]
FROM [identity].[AspNetUsers] u
JOIN #tmp_ldap_users tmp on tmp.[Id]=u.[Id]
-- create 'ad' directory connection
DECLARE @HostPartitionId int -- host partition id
SELECT @HostPartitionId = [Id] FROM [identity].[Partitions] WHERE [GlobalId]='FEB0DD79-85B6-483B-B297-0E49A1AA5B7D'
UPDATE [identity].[DirectoryConnections] SET [IsDeleted]=1, [DeletionTime]=GETUTCDATE() WHERE [PartitionId]=@HostPartitionId AND [Type]='ldapad' and [IsDeleted]=0
SELECT * FROM [identity].[DirectoryConnections] WHERE [PartitionId]=@HostPartitionId AND [Type]='ad' and [IsDeleted]=0
IF @@ROWCOUNT=0
INSERT INTO [identity].[DirectoryConnections] ([PartitionId], [Type], [CreationTime], [Configuration], [IsDeleted])
VALUES (@HostPartitionId, 'ad', GETUTCDATE(), '{ "Domain": "<FQDN-OF-DOMAIN>" }', 0)
SELECT * FROM [identity].[DirectoryConnections] WHERE [PartitionId]=@HostPartitionId AND [IsDeleted]=0 - Restart the Identity application pool by running
iisresetfrom an elevated prompt.
Switching from ad to ldapad
To switch your directory integration from ad to ldapad, follow these steps:
Check that the
WHERE p.[GlobalId]='FEB0DD79-85B6-483B-B297-0E49A1AA5B7D' AND dc.[Type]='ad' AND dc.[IsDeleted]=0 -
In the host portal, delete the existing Active Directory integration.
Reconfigure the directory integration, and under Directory integration select Configure.
noteWhen you switch from
adtoldapadall user settings and permissions are preserved, even during the delete and reconfigure steps. -
Restart the IIS services.
For example, you can use the
iisresetcommand in the Command Prompt to reset the IIS services.
