Skip to main content
Using external reporting tools
This page describes the object types and their corresponding attributes available for reporting purposes. To connect your reporting solution to those views, contact your system administrator. You can either use native SQL connections or your own reporting tools.
The following sections describe the object types and the attributes that you can check when using an external reporting tool.
Projects
The following table lists the available attributes of a Test Manager project in external reporting tools.
Table 1. Project attributes
NameData typeDescription
IdStringIdentifier for the project.
NameStringName of the project.
descriptionString (supports Markdown)Description of the project.
ProjectPrefixStringThe specific prefix of the project.
isActiveBooleanIndicates whether the project has been modified in the past six months.
isAuthorizationEnabledBooleanIndicates whether authorization is required for accessing the project.
isSapConfiguredBooleanIndicates whether there is an active connection to an SAP instance.
createdByStringThe email address of the Test Manager user who created the project.
createdDateTimeTimestamp indicating when the project was created.
updatedDateTimeTimestamp indicating the most recent update of the project.
Requirements
The following table lists the available attributes of a requirement in external reporting tools.
Table 2. Requirement attributes
IdStringIdentifier for a requirement created directly in Test Manager.
NameStringName of the requirement.
DescriptionString (supports Markdown)Description of the requirement.
ProjectIdStringIdentifier (GUID) for the project to which the requirement belongs.
ExternalRequirementIdStringIdentifier for a requirement synchronized from an external ALM tool in Test Manager.
ObjKeyStringKey of the requirement.
CreatedDateTimeTimestamp indicating when the requirement was created.
UpdatedDateTimeTimestamp of the most recent update to the requirement.
Test cases
The following table lists the available attributes of a test case in external reporting tools.
Table 3. Test case attributes
IdStringIdentifier for a test case created directly in Test Manager.
ExternalTestCaseIdStringIdentifier for a test case synchronized from an external ALM tool in Test Manager.
ProjectIdStringIdentifier (GUID) for the project to which the test case belongs.
NameStringName of the test case.
DescriptionString (supports Markdown)Description of the test case.
ObjKeyStringKey of the test case.
preConditionString (supports Markdown)Precondition of the test case, if exists.
RequirementsCollection or RelationshipsObject keys of the requirements assigned to this test case.
updatedDateTimeTimestamp of the most recent update to the test case.
createdDatetTimeTimestamp indicating when the test case was created.
AutomationProjectNameStringName of the Studio project which contains the automation assigned to this test case.
AutomationTestCaseNameStringName of the test case in Studio which serves as the automation assigned to this Test Manager test case.
Test sets
The following table lists the available attributes of a test set in external reporting tools.
Table 4. Test set attributes
IdStringIdentifier of a test set created directly in Test Manager.
ExternalTestSetIdStringIdentifier of a test set synchronized from an external ALM tool in Test Manager.
ProjectIdStringIdentifier (GUID) of the project to which the test set belongs.
NameStringName of the test set.
DescriptionString (supports Markdown)Description of the test set.
ObjKeyStringKey of the test set.
SourceStringSource of the test set, that can be either Test Manager or Orchestrator.
NumberOfTestCasesIntegerNumber of test cases assigned to the test set.
TestCasesList<String>List of the test cases assigned to the test set.
VersionDoubleVersion of the test set.
UrlStringThe URL of the test set inside the Test Manager project.
enableCovergaeBooleanIndicates whether activity coverage is enabled for the test set, and can enable if coverage information should be collected.
enforceExecutionOrderBooleanIndicates whether execution order is enforced for the test set.
createdDateTimeTimestamp indicating when the test set was created.
updatedDateTimeTimestamp indicating the most recent update to the test set.
Test executions
The following table lists the available attributes of a test execution in external reporting tools.
Table 5. Test execution attributes
IdStringIdentifier for the test execution.
NameStringName of the test execution.
ProjectIdStringIdentifier (GUID) for the project to which the test execution belongs.
DescriptionString (supports Markdown)Description of the test execution.
ExecutionTypeStringType of execution, which can be Manual, Automated, or Mixed.
ExecutionStartDateTimeTimestamp indicating when the test execution started.
ExecutionFinishedDateTimeTimestamp indicating when the test execution finished.
durationIntegerDuration of the test execution.
SourceStringSource of the test execution, that can be Test Manager or Orchestrator.
StatusStringStatus of the test execution: Pending, Running, Cancelling, Passed, Finished, or Cancelled.
TestSetIdStringIdentifier for the test set executed during this test execution.
testSetObjKeyStringKey of the test set executed during this test execution.
Total Duration (seconds)DoubleTotal time of the test execution in seconds.
Result Summary (P/F/N)StringFinal result of the test execution: Passed, Failed, or None.
Reporting DateDateTimeTimestamp indicating the reporting date.
Execution Order EnforcedBooleanIndicates if execution order was enforced.
Error RateDoubleError rate of the test execution.
Coverage EnabledBooleanIndicates whether activity coverage was enabled for the executed test set.
CreatedDateTimeTimestamp indicating when the test execution was created.
ResultsList<String>List containing the results of the test execution.
Test case logs
The following table lists the available attributes of a test case log in external reporting tools.
Table 6. Test case log attributes
automationIdStringAutomation ID assigned to the test case responsible for generating this test case log after its execution.
automationProjectNameStringName of the Studio project which contains the automation assigned to this test case.
automationTestCaseNameStringName of the test case in Studio which serves as the automation assigned to this Test Manager test case.
Business ResultStringThe business result of the test case responsible for generating this test case log after its execution.
DefectIdStringIdentifier for the defect resulted from the test case log.
DetailLinkStringTest Manager URL of the test case log.
DurationDoubleDuration of the test case execution.
Duration (seconds)DoubleDuration of the test case execution in seconds.
ExecutedByStringThe username or robot name who executed the test.
ExecutionEndDateTimeTimestamp indicating when the execution of the test case ended.
executionOrderStringOrder of test cases enforced during execution.
ExecutionStartDateTimeTimestamp indicating when the execution of the test case started.
executionTypeStringType of execution: Manual, Automated, or Mixed.
HasErrorBooleanIndicates if the test case encountered an error or not.
hostMachineNameStringThe name of the machine that executed the test case.
