Skip to main content
Automation project configuration
Navigate to the Automation tab within your Project Settings to specify a default Orchestrator folder for your project. This allows you to execute test cases only from specific packages and versions found within the chosen folder.
Roles and permissions
Only users assigned the roles of Test Manager Administrator at the tenant level or Project Owner at the project level have the ability to set the default Orchestrator folder.
Assigning a default folder
To assign a default Orchestrator folder to your project, perform the following steps:
  1. Select the Default Folder dropdown list.
  2. Select your preferred Orchestrator folder.
  3. Select Save to confirm your changes. The selected folder is displayed and will be used for all your test sets.
    note
    The Default Folder dropdown list only displays the Orchestrator folders to which you have access.
